Excentric turning and milling
Downloads
Technical data
● available
CNC Universal Milling Machine with swivel rotary table
High-precision, 5-axis control vertical machining center that uses DDM on rotary axes
Gear Production+ 5-axis milling, turning, gear roughing and grinding in a single set-up
Compact, precise, and process reliable with > 2 g acceleration and spindle speeds up to 60,000 rpm
Hybrid Complete Machining: Additive Manufacturing and Milling in one Machine
The entry machine for 5-axis simultaneous machining
High performance & precise universal milling center for parts up to D800 x 450 mm and 350 kg!
High performance & precise universal milling center for workpieces up to Ø630 x 450 mm and 300 kg on 6.4 m²
